Re: Zenith Carb venturi question
Posted by Bob M on December 02, 2004 at 06:12:56 from (151.190.254.106):
In Reply to: Zenith Carb venturi question posted by Bobcat on December 01, 2004 at 19:08:29:
Presuming everything else is set right (spark and cam timing, valve clearances, etc), sounds like it’s a chronic lean condition at idle. Most likely cause is a vacuum leak - ie. intake manifold to head, carb to manifold, worn carb throttle shaft bushings, etc.
To find the leak, with the engine idling and the choke full open spray WD-40 or play gas from an unlit propane torch on the suspect areas. The idle smooth out and speed will increase when the WD-40 or propane gets sucked into the leak.
If the above doesn’t do it, the carb idle mixture is chronically lean. If you slowly pull the choke with the engine warm and idling and find a choke setting where the idle smooths out, that’s the problem. You’ll then need to go back inside the carb and look for a partial blockage in the idle circuit, a wrong (too small) orifice someplace, a crack in a casting (unlikely), etc.
Good luck! Cause for a problem like this can sometimes be tough to locate…
Post a Followup
Subject:
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
