Re: help on 806
Posted by ejr on December 21, 2004 at 11:45:00 from (4.228.18.48):
In Reply to: help on 806 posted by Michael Earnest on December 20, 2004 at 23:50:30:
They will bolt up but their not long enough.Yes a 436 will bolt into a 806.I have a 706 thats going to have a 466.I have most every thing needed to do it .Two ways get a set of 66frame rails and the motor mount plate that will bolt into the 806.Use your front bolster but will have to shim between the frame rails and the bolster because the 1066 is a little wider than the 806.Or what Im doing is to use 806 frame rails redrill for the front motor mounts holes to match the 466 front motor plate which Ill narrow up to fit in the o6 narrower frame width.Also useing 560 hood because of its lengh the tractor will strech out a little needs the longer hood or use a 1456 hood its longer than a 806 hood.Also a cross over for the bottom radiator hose and throtle control moved to the left side.This takes care of most of the big stuff.
Post a Followup
Subject:
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
