Re: Running a 400 without power steering motor
Posted by billde on April 04, 2009 at 06:51:57 from (72.26.89.156):
In Reply to: Running a 400 without power steering motor posted by HSE on April 04, 2009 at 06:02:39:
HSE said: (quoted from post at 06:02:39 04/04/09) Bought a 400 farmall that somebody previously removed the Power Steering Unit (believe it was a behlen unit) in the steering shaft. My question is "What do I need to do to hydraulic system to run this tractor?"
Do I:
A: Loop hydraulic feed and return together?
B: Plug off both of them?
C: Remove a spring or priority valve or flow divider somewhere?
Not sure about A ..... will it cause other hydarulics not to work?
I figure B is wrong because flow will be deadheaded.
I have no idea about which internal valve to do what to on C.
I have a short piece of shaft already in place of where motor unit was. I also do plan on someday adding a power steering unit back in place. Serial number is #6556 if this makes a difference.
Thanks for any help!
If it was an add on Behlen, they were independent from the tractor hydraulics and you don't need to change anything. The Behlen had its own pump, reservoir, plumbing, and of course the torque generator.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
