Re: Farmall M steering adjustment.
Posted by Bob M on December 30, 2004 at 09:27:27 from (69.201.120.79):
In Reply to: Re: Farmall M steering adjustment. posted by D. Hilman on December 30, 2004 at 09:12:07:
I had that problem (worn worm & sector gear) on a Super H. It also had badly worn bushing under the sector gear. Solved both problems by slitting a new bushing shell before inserting it, then adding shim stock between the bushing bore and the bushing OD on the side away from the worm (left side of the tractor) to close up the bushing shell and offset the pivot shaft closer to the worm. Took some trial and error to get the right shim thinkness but managed to coax the sector gear about .030 closer to the worm which effectively took up the slop. Another possibility: Look carefully at the wear on the sector gear. It MAY be possible to shim the pivot shaft thrust bearing (at the bottom of the pivot shaft) to move the sector gear lower in the gearbox and thus cause the worm to engage the upper (and hopefully unworn...) portion of the the sector gear teeth.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
