1-Wire to 3-Wire conversion report
Posted by Dave in CT on January 01, 2005 at 00:25:48 from (64.252.220.240):
'47 H had a one-wire setup which I just converted to a 3-wire, using a Delco-Remy 10SI Alternator. Bought a connector to plug the wires into the 1 and 2 terminals on the 10SI alternator. Wired the 2 terminal to the BAT terminal on the alternator. Soldered a Radio Shack 1N4003 diode inline (banded end toward the alternator) on a wire from the shutoff switch to the 1 terminal on the alternator. The shutoff switch end was connected to the same pole as is wired to the + pole on the coil. This diode prevents the draw which can run the battery down. Tested the wire that had the diode. PASSED. Fired the H up and enjoyed seeing the voltmeter step immediately up to 14.5V just at idle - no running the engine up to mid-throttle to get the alternator to kick in. The one-wire setup is easy to install but the benefits end there. I do a lot of small and short jobs with my tractor. At times I've looked at the voltmeter and found I've been running for some time without the alternator kicking in. This post is to recommend going to the 3-wire setup if you've a 1-wire. One thing I wasn't happy with. The clearance below the hood with the 10SI wasn't much - with the connector made for the alternator, the wires stuck out and would get clobbered when I put on the hood. I cut slots in the connector to allow the wires to come out at 90 degrees to the back and that took care of it. If I were to do it again, I'd just use a couple of female spade connectors and bend them to come out the back. Thanks to Bob M and the others who helped me with this task.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
