Re: farmall h gears 4 or 5
Posted by williamf on January 03, 2005 at 01:21:20 from (66.82.9.80):
In Reply to: farmall h gears 4 or 5 posted by Jim Baird on January 02, 2005 at 21:10:33:
The shift pattern on the H looks like this:
R-2-4
1-3-5
If the shifter won't go into 5th, all the way to the right and pulled back, it could be, as Ray suggested, that the lockout screw is in place. That feature was mostly used for tractors with steel wheels rather than rubber tires.
If the shifter seems to go into the 5th gear position but the tractor doesn't move that's a different problem; either the shifter forks need work or, more likely, the teeth on the 5th gear are gone. This gear is different from the others in that it slides over a splined shaft rather than meshing teeth on the outside of the gear.(Does that make sense?)
I think you can at least see if the gear is moving as it should by pulling off the belt pulley, but I wouldn't swear to it.
Good luck, and let us know what you find, ok?
Wm
Post a Followup
Subject:
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
