Re: More crank bearings
Posted by scott#2 on January 12, 2005 at 08:32:14 from (138.88.166.64):
In Reply to: Re: More crank bearings posted by CNKS on January 12, 2005 at 07:15:08:
CNKS, I dont know much about tractors but I know about precision engines. Plastigage is primarily used for checking the grind job and bearing quality, to insure a accurate bearing oil clearance. I have had cranks come back that would not give a consistant reading across the journal. (bad dressing job on crank machine wheel) There are just too many variables in using plastigage on old/used parts to get a ballpark figure, especially since the ballbark is quite small when it comes to oil clearance. Block bores, rod bores, bearing quality (from different manufactures), bearings worn uneven, out of roundness, crush factors torque values, cleanliness on and on and on. I have even used different manufacturers bearings on the same engine when setting the bottom end up and often get different results. Plastigage is such an accurate way of measuring clearances that there is absolutly no room for variables or mistakes. Drop an eyelash anywhere in there and the reading is flawed. Dryer lint, cigarette ash, any contamination will give false readings. All readings should be taken with dry clean surfaces. This means block bores, main bearings (both sides), rod bores and their inserts (both sides). No oil, no nothing anywhere. If a journal is out of round or just round and worn to a smaller diameter, no amount of torque will push it down into the bearing for an accurate measurement. You only ues assembly lube (moly) on final assembly. Hope this helps, scott#2
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
