There are three external adjustments. The load screw is on the carb bottom front. It is a fine tuning screw on the main jet. It will tailor the fuel, not an absolute control. Normal is to start from about 3.5 to 4 turns out from a easy seated position. With it running at High Idle (full throttle no load) you should be able to get it to smoke a bit of black smoke traces. Thur it in until this goes away. Load test it to find out if it has black smoke under load. If so turn in 1/4 turn at a time till the smoke goes away. The second adjustment is the idle air screw. Top of carb on body. It is for slow idle only. It leans out the mix when screwed out, and richens when screwed in. Set for best idle when warm. The third is the idle speed, on the flange area of the governor tube at the throttle plate. Adjust to idle speed. Recheck the idle mix when this is set, then the idle speed to spec. Several cycles of this might be needed. White smoke is usually associated with coolant loss, not carb adjustment. Be sure it is not loosing coolant into combustion! JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
