H Steering shafts
Posted by Gordo on January 20, 2005 at 19:30:57 from (64.68.166.234):
I thought I had a lot of play in the steering shaft of my restoration project H.I replaced the bushing and seal at the front of the worm shaft.
But there is a significant amount of play where the worm shaft passes through the "center bearing". My worm shaft shows a lot of wear where it rotates in this part. But the center bearing is NOT a bearing it is just a cast piece. No bushing, no seal, no bearing. The shaft is worn a lot on the bottom side from turning in this support. If you grab the shaft and pull it back and forth there is a LOT of play there.
Now do I weld up the shaft to replace the worn metal, bush the "bearing" piece, or just allow all that play in the center support "bearing"?
Gordo
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
