Re: 986 TA fixed itself
Posted by captaink on January 24, 2005 at 08:09:59 from (66.115.214.56):
In Reply to: 986 TA fixed itself posted by Mapleridge on January 22, 2005 at 06:13:13:
To reduce or eliminate gear clash when shifting that speed transmission, you need to “double clutch” when you shift. “Double Clutching” is the process in which the operator synchronizes the gear speeds manually. “Double clutching” is a process that needs to be done in the “blink of an eye” in order for it to work successfully. Here is how to do it in a nutshell. You mention down shifting under a load. When the engine is under below the speed that the throttle is set at, depress the clutch far enough to release the pressure on the gears but not engage the transmission brake and move the speed lever to a position between gears. Release and re-engage the clutch (again not far enough to engage the transmission brake) and when the engine hits the RPM that matches your ground speed for the lower gear, slip (don’t try to jam it) the speed transmission into gear and release the clutch. It sounds a lot simpler than it really is and takes lots of practice and knowledge of the relationships between the engine RPM and ground speed in various gears. To shift to a higher gear, you need to have the engine at a high RPM, engage the clutch, move between gears, throttle down, and momentarily release the clutch, and then slip the gear shift into the next higher gear when the engine RPM is matches the ground speed in that gear. If you know a truck driver that has been around the 13-speed transmissions, he probably will be able to show you how to shift without even using the clutch! At any rate it takes practice and a good ear for engine speed (or know the shift points on the tachometer) to make a shift while moving without “grinding” the gears. Good luck!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
