Last Try On Roosa Master Pump.
Posted by Davis D. on January 25, 2005 at 18:14:58 from (64.12.117.13):
I have been trying to start my IH 504 after a rebuild but can not get fuel to injectors Here is what I have done. I bled the fuel to the pump. Eventually got fuel into the injector pump and to the return line,(after about 2 hours of cranking and charging the battery repeatedly). At first I did get fuel to the injectors but then it stoped. I took the end cap off the pump and checked the screen to make sure it was clear, it was. I also checked just to make sure the pump was turning, it was. After re-installing the cap I took off the rectangle top over the governor and made sure it was moving and also worked the fuel shut off. Both seemed ok. I turned the motor over to see if any air bubbles came up through the pump. None showed and the fuel level did not rise in the chamber.
I tried putting slight air pressure in the tank to move fuel through the pump but it did not help.
I checked the lines to the injectors and they are clear. I turned the engine with the a line off but did not see any fuel come out.
What next.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
