Re: Super A coil
Posted by K.B.-826 on February 22, 2005 at 19:48:42 from (209.163.30.23):
In Reply to: Super A coil posted by Cris on February 22, 2005 at 18:28:35:
First we need to eliminate the possibilty of a fuel-flow problem. Look at the bottom of the carb bowl. You'll see a plug. Get yourself a container and the wrench to remove the plug. Run the engine until it stalls, then quickly move your container under the carb and remove the plug. If you don't have a strong, steady stream of fuel coming out of that plug, there's a restriction somewhere between the tank and the carb. That's the most common thing that would cause the type of problem you describe. The next most common thing probably would be the coil. The coil you describe sounds different, but should have worked. There are three types of coils- 6 volt, externally resisted 12 volt, and internally resisted 12 volt. With a 12-volt system, the voltage going to the coil needs to be reduced to 6 volts, to avoid burning the points. A resistor is used to accomplish this, the only difference between the two is the location of the resistor. A 12-volt externally resisted coil will be the same as a 6 volt, if you don't have a resistor wired in ahead of it, but if you get a internally resisted coil by mistake and try to use it with your 6 volt system, it will cut the voltage to the points to almost nothing.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
