Re: 240 governor
Posted by scotty on February 24, 2005 at 11:46:39 from (199.231.49.128):
In Reply to: 240 governor posted by chuck kaufman Ore. on February 24, 2005 at 11:04:05:
Chuck, The only way you could have got it 180 out is if you took the mag off and reinstalled it, and turned the drive keys 180 before reinstalling. Allways a good idea to have your rotor pointing to #1 plig wire after removing the cap before pilling the mag. Anyway, you had your govenor housing off to put a new thrust bearing in. You would have had to pull the govenor gear out quite far to get it out far enough to be one tooth off.If you did pull it out that far I think at this point you need to get the tractor back on TDC. You will need to take the bottom flywheel cover off to find your TDC line on the outside diameter of the flywheel. It is a very light line and hard to find but it is there. Once you find it, take your spark plugs out and have someone hand crank the engine while you put your finger over the #1 plug hole until you feel piston coming up on compression stroke. Watch for your line to come up on the flywheel. At this point your rotor should be just coming up on your #1 plug. scotty
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
