Posted by Bob O2 Martin on April 05, 2009 at 07:49:44 from (69.66.16.186):
In Reply to: Farmall H bendix??? posted by beochie on April 05, 2009 at 07:21:22:
First pull the starter, ground the case and jump onto the current feed for the starter. See if the bendix is sliding up the shaft. If it isn't, lube the shaft with a penetrant/lubricant. a lot of times that takes care of the problem.
If you have to remove the bendix, take out the two long bots that hold the starter together and pull off the starter head. There is a little clip that you take off and the bendix will slide off. Reassembly is pretty simple.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
