Posted by JimB2 on April 05, 2009 at 08:56:14 from (99.240.236.11):
In Reply to: 454 help needed posted by ljw on April 05, 2009 at 08:22:38:
Hi, my first disclaimer, I have never worked on gas model of 454 only Diesel model but the usual cause of the stumbling when throttle is advanced rapidly is to lean of gas/air mixture. One of the causes was vacuum leaks and since you have replaced the manifold gasket it s probably not a vacuum leak. Another was the low speed/idle jet being adjusted to lean. I looked at caseih.com parts for C-152 gas engine carb and did see an idle adjust screw for carb, so try openning idle adjust screw an 1/8 of a turn at a time and see if this helps any.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
