Posted by John T on April 05, 2009 at 10:13:28 from (66.244.97.31):
In Reply to: farmall h electrical posted by bennyboy2383 on April 05, 2009 at 09:39:29:
Even if it was converted, since its a Magneto Ignition, aside from possibly burning out some 6 volt lights if you put 12 volts to them, EITHER a 6 or 12 volt battery should crank the starter over to get it running (Unless it was actually converted to a 12 volt starter which I doubt, in which case it needs 12 volts to crank it properly).
If you stuck a 12 volt battery in, it will indeed crank it over and pretty fast if its still a 6 volt starter, and since its a a Mag you wont harm the ignition
Id venture a pure "guess" it was and still is a 6 volt Positive ground system.
Since its an H and they arent that difficult to crank over, I'd use a 6 volt n wire it Pos ground n keep it at 6 volts and use a good heavy duty 6 volt batery and 00 gauge Battery n Starter n Ground cables, and get a good 6 volt genny and VR.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
