Farmall Tractors Discussion Board |
Re: WIDE narrow
Posted by Stability: Kim (NY) on December 05, 1999 at 09:20:01 from (137.142.50.10):
In Reply to: WIDE narrow posted by T'other Fred on December 04, 1999 at 19:02:17:
It is correct that the majority of the stability in a tractor comes from the width of the rear axle, but it is not correct that the front end does not effect this stability. It works like this. On a tricycle front end the "roll" line, the line upon which the tractor's cg is calculated is a line from the rear tire to the center front of the tractor, in other words a diagonal line. This can cause a less than intuitive manner in which a rollover can happen because the height above the ground that the cg is placed is not parrallel to the ground but increases in height from very low at the front of the tractor to quite high at the back, this is one of the reasons why loaders on narrow front ends are especially dangerous. I believe that a major advantage of the narrow front end however was the triangle's ability to keep all 3 points in contact with the ground therefore increasing traction. A wide front end tractor can easily lift a rear wheel off the ground well before it reaches a point close to rollover, however a narrow front end tractor will keep all tires in contact with the ground....until it goes over....and then it will do it very quickly. In other words a narrow front end will roll over almost immediately after a rear tire leaves the ground. This is the safety factor in the rocker on the front of a wide front end. The operator has the margin between when a rear tire leaves the ground through the motion of the rocker until the front tire leaves the ground to correct a rollover potential. Once you lose two wheels on the same side however you'd better have your seat belt on and your ROPS installed. Good Luck Kim
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
