Re: M oil pump ??
Posted by Slappy on March 21, 2005 at 03:24:14 from (143.88.86.44):
In Reply to: M oil pump ?? posted by JonM on March 20, 2005 at 08:53:35:
John, I'm not sure about the M pumps - I'm working on an H and they are all the same for that model. What I would do is check the clearance on each. Pay close attention to the following: 1 - gear backlash should probably be around 0.006 or so. You can still get NOS gears if needed. 2 - Side to side play in the shaft. This should be minimal. If you have play check the clearance between the the casting and gears; if it's out of spec look for a new pump. 3 - Check for end play in the shaft. Should be 0.005 or less. If its out, you can knock out the pin in the drive gear at the top, pull the gear with a puller and get some shims to place under the gear from someplace like McMaster and Carr to make up the play. If you had some play you will have some galling on the bottom end plate that will need to be taken out. Either grind it out yourself using grindind compound and a flat surface ot take it to a machine shop. Ive heard some people argue that thes pump is submersed in oil and so don't wear out, but that's not true. I think that many people believe this because those pumps were really over-engineered and will give good oil pressure even if they are worn. So I guess that the take-home message is, that the pump dosen't need to be perfect to do a respectable job.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
