Re: C has a cracked block
Posted by David in UT on March 30, 2005 at 14:23:34 from (208.15.63.195):
In Reply to: Re: C has a cracked block posted by Andrew Z on March 30, 2005 at 11:53:33:
re: welding the block, there are two schools of thought on welding cast iron. In both cases, you would use a nickel rod. There are several different versions of a nickel rod with slightly different characteristics. One is better for machining after the weld, for example. The crack must also be accessible enough that you could grind the edges down to make a nice V for the welding. One school of thought says preheat the casting thoroughly, perform the weld, then pack the casting in sand so that it will cool very slowly. The other way is to work on the casting cold, but to make a lot of very short beads (no more than an inch at a time), and wait between beads to give the heat time to dissipate through the casting. I've done some cast welding, and I've used the second approach, mostly because I don't have an oven for preheating. So far, it's worked out for me. I will add, however, that I haven't tried it on a block, and if the crack is between the cyclinders as others have said, I don't think I'd try -- just too hard to get clean access to the weld area. The mixed up stuff referred to in an earlier post is JBWeld -- sort of an epoxy for metal. It's great stuff. Good luck, - David
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
