Farmall Tractors Discussion Board
Re: Farmall Super H Jumps out of fifth gear
Posted by Rich Cota on December 07, 1999 at 04:40:55 from (198.56.12.229):
In Reply to: Farmall Super H Jumps out of fifth gear posted by Len Perron on December 06, 1999 at 13:03:07:
My experience with this problem is that the 4th and 5th sliding gear is worn out. You don't have to split the tractor to replace but, you do have to pull out hydralic pump,gas tank and transmission cover plate. You must disconnect the drive shaft and take the end off the upper set of gears that sticks out of the trans. The upper set will unbolt and can be lifted out by pulling them backwards out of the trans. You must replace the bearing on the end of the shaft and the sliding gear. I would also check those things mentioned in the previous post.
Post A Followup
: Re: Re: Farmall Super H Jumps out of fifth gear
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
