Farmall Tractors Discussion Board
Fluid Changes on a Farmall 400 which Sat Idle for Years
Posted by Larry on December 09, 1999 at 16:37:47 from (208.164.249.148):
Looking for advice on how to proceed regarding fluid changes for a Farmall 400 which sat idle for a number of years.
I have changed all fluids twice. However, the engine oil and hydraulic system oil comes out as black as the first time I changed it.
Also, I noted what appeared to be metal filings in the engine oil filter assembly and white foam where engine oil is added ( located forward of the hyraulic pump).
The engine oil pressure indicates good (high end of the scale) at all power settings. However, engine performance is sluggish which was partially attributed to govern and/or distrubutor shaft problems (as previously suggested by the Farmall discussion group).
The hydraulic system appears to be functioning properly as the Dual 350 loader operates nicly.
Should I consider adding SeaFoam to the engine oil? What can be added to the hydraulic system to address mositure contamination? Note that I am using a turbo quality oil for the engine and Case-IH Hytran for the hydraulic system.
Also, are there any add-ons available to the hydraulic system (i.e., filters) that would extend fluid life and/or enhance performance?
Thanks in advance.
Post A Followup
: Re: Fluid Changes on a Farmall 400 which Sat Idle for Years
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
