Axle ratios, etc
Posted by CNKS on April 26, 2005 at 13:54:15 from (204.249.178.138):
In 1992 I bought a GMC K1500, 350 cu in, automatic, 3.42 rear axle. Since then I have developed tractor disease and tow occasionally. My half ton is not a towing vehicle. I have added an extra capacity trans oil pan and an external trans oil cooler. Oil temp hits 230-250 degrees even in "flat" Kansas because of the usual head or cross wind. Pickup has 83000 miles (just broken in) and is in excellent condition, inside and out. A $30000 3/4 ton (including trade, rebate and sales tax, GMC 2500HD 6.0, 4.10) is not an option because I only tow once a year or so for any distance. Transmission is a 4L60 (700R4), the small one. Towing "capacity" is about 6500 lbs, meaning on flat ground with a tailwind -- that situation never happens. The trans will overheat against the wind even when towing a Farmall C, less than 5000 lbs including the trailer. Does anyone have this combination with a 3.73 or 4.10 axle ratio, and will this allow me to do my occasional towing without eventually melting my transmission? Lower gears (high numerical) would also help unloaded travel, as the lockup disengages on the slightest incline. The thing is simply geared too high--I am somewhat hesitant to go to 4.10, as I would need that gearing only for towing. Empty in overdrive it turns about 1800 rpm at 70 mph, with a 4.10 that would be about 2200 rpm -- perhaps that's not too bad, still lower than the rpm before overdrive became common. I don't know how much the 3.73 ratio will help. Would have to do both axles -- read on one of the towing forums that it would cost about $1500 for both axles, so it needs to work. There are also underdrive/overdrive split range (2 speed axle) attachments, more like $3000 for those. I realize I can't make a 3/4 HD out of it, just want something that will work for occasional towing, within the rated specs. All comments except--buy another pickup--are welcome.
- Re: Axle ratios, etc Haas 13:32:25 04/27/05
(0)
- Re: Axle ratios, etc dbNga 09:21:00 04/27/05
(0)
- Re: Axle ratios, etc onefarmer 08:21:59 04/27/05
(0)
- Re: Axle ratios, etc lee 06:43:41 04/27/05
(1)
- Re: Axle ratios, etc NDS 06:05:28 04/27/05
(0)
- Re: Axle ratios, etc dave from MN 05:51:59 04/27/05
(0)
- Re: Axle ratios, etc K.B.-826 20:51:27 04/26/05
(0)
- Re: Axle ratios, etc lee 18:55:22 04/26/05
(1)
- Re: Axle ratios, etc Paul Shuler 17:25:34 04/26/05
(2)
- Re: Axle ratios, etc ChadS 17:24:08 04/26/05
(1)
- Re: Axle ratios, etc Bob 15:57:46 04/26/05
(0)
- Re: Axle ratios, etc Hugh MacKay 15:44:19 04/26/05
(6)
- Re: Axle ratios, etc lee 15:41:32 04/26/05
(2)
- Re: Axle ratios, etc 26Red 14:32:02 04/26/05
(2)
- Re: Axle ratios, etc CNKS 14:17:30 04/26/05
(1)
- Re: Axle ratios, etc RustyFarmall 14:16:51 04/26/05
(2)
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
