Re: 1206 brakes
Posted by the tractor vet on May 15, 2005 at 13:49:09 from (4.124.67.97):
In Reply to: Re: 1206 brakes posted by BODE on May 15, 2005 at 08:17:49:
There is a check valve in the fitting on the line that goes into the brake control valve but all that does is hold oil in the valve when the engine is off and will littel or no effect while running . Unless ya got a service manual or and I T manual it is hard to understand and it would take up a lot of band wideth for me to walk ya thru everything . First ya need a pressure gauges that will read 600 lbs. a liquide filled prefered a JIC fitting to go into the bottom plug of the MCV and hook up to the gauge . then ya need atleast 200+ lbs on the MCV i like 265-285 , i use (2) gauges but then ya need the special test tool for the dump valve but you can get and idea of what you have with one. I would bet that your problem is in the MCV on the flow devider from a weak spring or sticky valve. It is not common that the brake vavle is the problem . Sometimes this is caused by the adjusters getting stuck on one side and you have to force the brake to stop only on half or you could have a brake seal leaking or a piston O/Ring seeping and allowen oil on the brake this will also give about the same resualts . Like i said before i need a lear jet to run around and fix all the had problems for you guys cause i can fix them just about as fast as i type.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
