Re: farmall super C don't start
Posted by El Toro on May 20, 2005 at 19:19:25 from (205.188.117.138):
In Reply to: farmall super C don't start posted by donny on May 20, 2005 at 18:40:01:
You need to check to see if you're getting a good hot spark to the plugs. Pull off one of the plug wires and hold it about 1/4' away from the engine block and have someone crank over the engine with the ignition switch on. You should have a hot spark if the ignition is ok. If the spark looks ok you need to check for gas at the carburetor. Pull the distributor cap and check for a broken rotor, but I doubt if this occurred. The easiest way to check to see if it jumped timing is is to pull No1 plug near the radiator and have someone crank the engine by hand while you hold your thumb over the plug hole until you feel compression against your thumb. Then stop the cranking and you look for the timing mark on the flywheel. You want that mark aligned with the indicator. Your No1 piston should be at TDC. Pull the distributor cap off and see where the rotor is pointing. It should be pointing to No1 plug wire. You may want to put some chalk on that timing mark. By the way that's on your tractor's flywheel. Hal you fee
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
