If you've got a generator and three caps on the battery, that IS 6-volt. A 12-volt woold have six caps on the battery and COULD have a generator, but more likely an alternator.
So . . . double check that you have a) a 6v coil--part number check with the parts house if it isn't stamped or printed right on it -- and b) that you have the same pole running on the small wire from the coil to the distributor as what you have grounded on the battery. Positive for both would be the standard setup.
And just for giggles, you might try popping your old condensor back in when you go in to double-check the points.
Check all that out before you go getting another set of wires. Also, if you didn't do it that way in the first place, the tip above about stripping the wire back and turning the stripped wire back over the end and onto the insulation to make contact with the terminal is a good one.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
