Re: super m carb serial number
Posted by ChadS on June 14, 2005 at 08:08:13 from (66.228.96.174):
In Reply to: Re: super m carb serial number posted by farmall on June 13, 2005 at 22:25:50:
Better have a second look at the idle circuit in the throttle body, and the carb bowl. Its running off the main jet for some reason. Two reasons the carb will do that. Either the idle passage is plugged in the air side of the circuit, not letting air pass by the throttle shaft at idle, 9 times out of 10 its plugged up, and causes this symptom. It will pull the fuel from the metering stem instead of the idle passage. If you have a 6 volt system, do you have the electronic conversion kit, or still running points? If your running points, on 6 volts, no resistor, then put on a 12 volt coil, and no resistor at 6 volts, or what ever your generator puts out, it will give it a little more spark, and not be so bad on the point contacts. Its either that, or convert it to 12 volt, or get the conversion kit. On the Super H rpm at idle,, check the top bolt inside the governor for the idle adjustment speed. With the linkage in idle, (not running) with the governor cover off, see if the top adjustment bolt is touching the housing, if it is, back the bolt out a few turns, this should bring the rpms back down. It is a heavy spring, and it takes the tension out of the governor tightens it up I guess you could say,, and some need to be adjusted to compensate. ChadS
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
