Re: Restored C needing Fire to the spark plugs!!!!
Posted by Bob on June 19, 2005 at 14:27:05 from (66.163.134.177):
In Reply to: Restored C needing Fire to the spark plugs!!!!! posted by BamaLarry on June 19, 2005 at 13:26:31:
Assuming it is still positive ground, your wiring sounds correct. Check for power with a test light, on the (-) post of the coil.
If you have power there, put the test light on the (+) (distributor) side of the coil, and try to start the engine. The test light should flash "ON" and "OFF" as the points open and close.
If the test light NEVER comes on, it indicates a short in the points/condensor area, or points that are not opening.
If the test light is "ON", and NEVER blinks "OFF" as the engine is cranking, it indicates an "open" connection in the primary circuit to the points, points not closing, or dirty points.
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
