PROVIDED your carb is original, the Super M carb main jet is supposed to be adjusted about 3-5 turns out. The 5 turns will be too rich for all but maximum loads. Adjust it out until it does not stumble under load. This is probably about 3-3.5 turns off the seat. If this does not work, your carb needs cleaning. The main jet on the M carb is adjusted in until rough, out until smooth plus maybe 1/4 turn more -- This results in too lean a mixture for a SM carb, and is perhaps the reason some adjust between rich enough to smoke and lean enough to stumble (some call it the "sweet spot" -- I don't do it that way.
This post was edited by CNKS at 14:53:40 04/06/09.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
