Re: 300 hydraulic pump rebuild
Posted by George Mikesell on June 19, 2005 at 21:58:52 from (209.42.79.128):
In Reply to: 300 hydraulic pump rebuild posted by jmyt_47 on August 16, 2001 at 08:06:55:
Your pump has no gaskets internally, it does have two orings on brass backing pkates, and one on outer case, you can get orings at about any parts store and or buy kit to make your own,Seals also can be gotten at parts stores. As long as your gears are not scored, and the backing plates if scored can be surfaced on piece of glass or flat metal, with 180 grit wet dry paper. The major problem is if the spring backing plate is applying enough tension on brass backing plates to keep pump from bleeding by. If this is a problem you can put in .030 spacer which you have to cut out of brass shim stock or steel. No one provides this it is a home job. It has been my experience that the backing plates get weak over time and need some help, sure wished could buy new ones. Any way this will usually put the pump where it will produce 12-1500 lbs pressure.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
