Re: IH B414 Transmission Problems
Posted by Janicholson on June 21, 2005 at 11:54:43 from (199.17.6.175):
In Reply to: IH B414 Transmission Problems posted by Ned C on June 21, 2005 at 06:49:22:
There are two possible issues. 1} the shifter leaver tip that moves the shift rails in the transmission could be worn on the end. (PROBABLE) 2}The actual drive gear on the shaft could be engaged, but not on its shift fork. (LESS likely) Determine which gear the tractor moves in when in neutral. It might also not shift into this gear when moving the lever. Using a Manual or parts book, disassemble the shifter pivot down at the trans and pull it out of the housing. Use a good little spot flashlight to light inside the hole and see if you can see a rail/slot out of position for that gear (it will be in a location opposite of the position for that gear in the pattern because the pivot reverses the direction of motion. Use a fair sized screwdriver, with the clutch down, to move this shift rail/slot back into alignment with the remaining rails (this is neutral, test it by starting the tractor and releasing the clutch, (it should now not move and the engine should not be pulled down). The tip of the lever (that you pulled out should be appearing worn on the trans end. This tip usually (but not always) looks like a flattened disk, or 4 dimes stacked on each other. It needs to be welded up and reground to its original size. If you can get tough alloy welded onto the original tip, the part will never fail again. If problem #2 is the case pulling the trans cover off, and doing major surgery on the gears/rails/forks, and detents may be needed.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
