Re: 806 amp light
Posted by Bob M on June 28, 2005 at 06:39:35 from (151.190.254.108):
In Reply to: 806 amp light posted by Farmer Gene (NW WI) on June 28, 2005 at 06:17:40:
Gene - Sounds like the alternator is going away. A voltmeter across the batteries should indicate least 14.0 volts with the engine running. Your reading of 13 is too low - the flashing light is further indication something's amiss.
I've had a couple fail the same way. In both cases it was the internal regulator gradually failing. For about $12 you can replace the regulator. And it can be accomplished without removing the alternator.
However for another $30 - $40 you can replace the alternator with a fresh rebuild containing a new regulator, brushes, bearings, etc. That would be my recommendation!
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
