Re: Farmall C Charging Problem
Posted by Bob on July 10, 2005 at 00:19:53 from (64.21.249.40):
In Reply to: Farmall C Charging Problem posted by Brian Schmidt on July 09, 2005 at 20:18:12:
You DO NOT polarize a regulator, you polarize the GENERATOR, (even though you may be making the connections at the regulator to do the polarizing). Polarizing restores the residual magnetism in the generator's polepieces AND restores it in the correct direction, so the generator will charge with a polarity matching that of the battery. Before starting the tractor, put a GOOD jumper wire from ther generator's "F" terminal to a good chassis ground. Be sure the connections are clean at both ends, and making good contact. If the generator charges at startup (it will be full-charge with the jumper wire in place), it points to a bad regulator, specifically dirty points on the voltage/current regulator unit, or even a bad ground. If the generator DOES NOT charge at start-up full fielded in this manner, it points to generator problems, which could range from a dirty commutator/bad brushes to a bad solder joint on one of the commutator bars, to a shorted winding. Conductive debris between commutator segments can cause this problem. Try cleaning out the "undercuts" between the commutator bars with a broken hacksaw blade that has been ground thinner to match the thickness of the groove between the segments. The use of an armature testing device called a "growler" can check for several of the previously mentioned problems.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
