Re: Deisel injector pump
Posted by Ron in Nebr on July 12, 2005 at 23:00:48 from (65.172.143.46):
In Reply to: Deisel injector pump posted by Richard Fazio on July 11, 2005 at 17:43:38:
I tried to post last night but it didn't come up, so here goes again.....
Check the simple things first, like the screen mentioned below. It's in the inlet fitting on the primary pump. Also, wouldn't hurt to make sure the petcock on the bottom of the deisel tank is open! The fuel on these goes through the water separator, then the primary(rear) filter, then through the primary pump, then to the secondary filter, and then to the main injection pump where the guage is.
If you have fuel at the bleeder on top of the primary filter you're ok up to that point. Sometimes if the tank is low it won't gravity bleed through the primary filter.
Pull the output line off at the primary pump and see if there's fuel coming out there while it's running on gas.
If not, then there's problems in the primary pump.
There's a pressure relief valve in the primary pump that could be stuck.
The gears in the primary pump are driven by and secured to the shafts by small roll pins. One of these could be sheared.
In a worst-case scenario, you may have the same problem I had on my 650D. The primary pump is driven by a small square hex that's machined onto the rear of the governor shaft inside the main pump. On mine, this square hex was rounded off and the primary pump didn't turn. I had to pull the whole thing apart, weld and file the square hex back onto the rear of the governor shaft, and then it all worked fine again. Had to make almost all the gaskets myself, but some of the seals are still available from IH and other places.
Good luck!
Post a Followup
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
