Re: Farmall H fluid check levels
Posted by farmallhal on July 16, 2005 at 08:03:58 from (64.24.35.16):
In Reply to: Farmall H fluid check levels posted by Kevin on July 16, 2005 at 06:02:01:
Kevin, If you are going to disconnect the drive coupling to your hydraulic pump you can just drain what remains in the pump through the drain plug on the bottom of the pump. It will be fine empty with the drive coupling removed and that will stop the source of leaking hydraulic fluid. Also, several folks use non-detergent 30 wt. oil in the pump which might not leak as bad as hydraulic fluid. You might want to also just change out your transmission/differential fluid if it hasn't been changed in several years. Depending on the climate where you live (and if the tractor is stored outside) it tends to collect water. You can check for the presence of water by loosing the drain plug to the point where fluid can seep out. You should be able to see if you have water present after the tractor has set overnight by what seeps out around the drain plug. If it is milky colored you have water present. Have fun on your tractor cruise.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
