Re: cub 154 steering
Posted by L.C.Grey on July 24, 2005 at 06:28:53 from (65.174.44.222):
In Reply to: cub 154 steering posted by Kevin Mars on July 23, 2005 at 05:56:29:
I recently had the same problem with my 154. Your machine won't turn right because it has to pull the drag link rather than push it. At first it appeared the bracket from the left side was broken, but when you disassemble it you will most likely find the larger bracket from the crossmember of the frame is broken off through the middle bolt hole. That causes the steering box to be pulled away from the frame during a right turn rather than it pulling the wheels around. Mine was particularly difficult to fix because some yahoo had tried to weld the aluminum steering box to the steel bracket somewhere in the past. Its very dificult to get to, so I ended up cutting the entire bracket and part of the crossmember out to be able to properly repare it on the bench. I replaced the section back in afterwards and braced it up. The outer bracket that to you see is pretty difficult to get into place. I'd plan on pulling the arm off the box and dropping the whole box and column out the bottom. It all comes off pretty easily. I tried everything without removing the box and column, and ended up pulling it all anyway.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
