All of the above is good advice. Another possibility is points never opening inside distributor (adjusting screw came loose, perhaps) or a short to ground (failed condenser, or condenser wire shorting to case). I would first to do the spark test, and expect a fail. Then I'd use light or VOM to check coil wire at coil and key switch (with points open). If you do the hot wire jump to coil, be sure to pull the existing one as we suspect a short to ground. If that fails, and voltage is good to the coil, , then I'd test voltage along the way from from coil to moving point. Also make sure voltage disappears when points are closed. That done, you begin to suspect the coil itself.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
