Re: H Magneto Problem
Posted by Red Dave on August 23, 2005 at 10:21:49 from (24.104.94.34):
In Reply to: H Magneto Problem posted by Leee on August 23, 2005 at 09:46:07:
You probably got the rotor out of time when you put it back together. It's easy to do. The plate over the points has a gear drive in it.
Take out the plugs, put your thumb over the hole to #1 & have somebody turn it over slowly. When the pressure pushes your thumb away, it's on it's compression stroke. Shine a flashlight in the plug hole and see when #1 is at Top Dead Center of the compression stroke. When it is, set the rotor to the distributor contact for #1 plug wire.
Should fix you up.
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
