Re: SUPER C STARTER PROBLEM - NEED HELP.
Posted by John T on August 29, 2005 at 15:12:18 from (66.244.90.98):
In Reply to: SUPER C STARTER PROBLEM - NEED HELP. posted by farmallhal on August 29, 2005 at 07:49:52:
Hal, Im not all that familiar with Farmalls, more experienced in Mother Deeres, but have found the problem often is EITHER the copper looking button/post on the starter OR the washer/contactor in the switch is pitted/burned/carboned up. If the starter post is all burned n pitted I have gotten temporary relief by cleaning n wire brushing n light filing it down smooth (If its burned/pitted too deep, it needs replaced) HOWEWVER, if the contactor/washer on the switch is burned or pitted or carboned up badly, it needs replaced. Also, if theres any mechanical restrictions or limitations in the rod n linkage that prevents depressing the switch fully, that can cause arcing n carbon build up in the switch. I dont have much luck by jumping direct with a big battery cable to the starter post, cuz it tends to arc badly and its hard to keep a good electrical connection. Also the real test is if the starters under a load as that direct jumnp test dont tell you as much if the starter is able to free spin unloaded. Its possible for a starter to become mechanically stuck/jammed with its drive gear into the flywheel teeth, so check that out first by loosening n rockign before you try any starter jump tests. A bench test can tell you some as the starter should torque kick pretty hard upon start and spin pretty fast and if not, shes obviously BAD, but thats not under a load so its no guarantee its still good just cuz she runs good not loaded. If the starters not too bad, I have had luck simply by taking it apart and cleaning things up and polishing down and removing any film from the commutator. Good luck n God Bless John T in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
