Re: How to prime M hydraulics
Posted by Janicholson on September 07, 2005 at 08:25:23 from (199.17.6.175):
In Reply to: How to prime M hydraulics posted by Mel in OR on September 06, 2005 at 21:38:48:
Others may use different means to the end, here is mine. I would disconnect the pressure hose from the control valve system (the pressure out hose from the pump) and tie a clean shop towel sized rag around the end in a loose pocket wired on to prevent spraying. I would place this in an empty clean 5gal. pail. I would plug all ports except the top (filler) port on the belly pump. I would then use a tubeless tire valve stem with a rim end big enough to fit into and block the fill pipe on the belly pump. I would have a helper on the seat that can start and shut off the engine on command (reliably). Using a regulated air hose set at 15 psi, or a portable air tank with 15 psi in it, or a bicycle pump, I would pressurize the belly pump. Have the helper start the engine at just above idle. The air pressure will push hyd oil into the pump and prime it. just as soon as the oil starts to come out of the hose in the bucket, shut off the engine. Hook up the hose and you should be in business. Do not use shop pressure, I don't think the seals on parts of the belly pump are designed to take much pressure. Good luck, Jim Nicholson
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
