Re: Farmall Cub 6 volt jump started with 12 volt
Posted by Janicholson on September 07, 2005 at 12:50:14 from (199.17.6.175):
In Reply to: Re: Farmall Cub 6 volt jump started with 12 volt posted by EricB on September 07, 2005 at 11:32:49:
I have done it (not a great policy, but expedient). My first method eliminates the exposure of the 6v battery to 12v. To keep sparking away from the tractor battery, connect the positive post of the fresh 12v battery/vehicle to the tractor's battery cable coming from the positive battery post. (this means :at the far end of the cable not the battery end. It might be the ground strap location if Pos. ground on the tractor, probable.) Then connect the negative jumper to the Fresh battery/vehicle. The next step is the key to this action.!!! Put it in neutral, set the brakes,turn on the key, then forcefully touch the other end of the Neg jumper to the starter side of the heavy switch on the starter, or solenoid. The starter now spins with no connection to the 6v battery at all. If the tractor battery is completely dead, or internally open, this method will not provide coil ignition spark. Mag ignition does not care. If the tractor system is negative ground(not likely) hook up the negative fresh battery/vehicle jumper to the tractors ground point as described above. OR!!! With all accessories/lights off, touching the negative jumper clamp to the battery side of the solenoid, or heavy switch will provide this voltage, but someone must be trying to start the engine with the key/button/lever/push rod, to make the starter turn. This last description is not recommended by me, as it does place 12v across the 6v battery. Always maintain control of cables and clamps. Never use 12v the first way for more than 15 seconds. Never use the second way more than 5 seconds. If it does not start something else is wrong with it. JimN
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
