Re: 350U will not run
Posted by El Toro on September 19, 2005 at 18:45:57 from (152.163.101.13):
In Reply to: 350U will not run posted by Mark and Anik on September 19, 2005 at 17:39:45:
I would bring No1 piston up the compression stroke to TDC. You need to remove No1 plug near the radiator and feel for compression against your thumb as someone handcranks the engine. Stop cranking when piston is at TDC and the timing mark is aligned with the pointer. Check the rotor to see where it is pointing on the cap. It should be at No1 plug wire in the cap. If this appears ok you should check the point gap and clean the points. Gap is probably .020". After this, check for fire at your sparkplugs when cranking the engine with the ignition switch on and using the starter. No fire I would replace the points and condenser and try again & check for fire. I would drain the old gas and put in fresh gas too. Still no fire I would buy a new coil. Hal PS: Check for battery voltage at your coil with ignition switch on with a lite or volt meter.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
