Re: 350 Utility Oil Leak
Posted by Unreserved dick on September 21, 2005 at 01:31:19 from (4.228.126.89):
In Reply to: 350 Utility Oil Leak posted by Jeff in Cincinnati on September 20, 2005 at 17:33:22:
Directly below the battery is the TA compartment. It has two holes where excess transmission fluid drains out when the fluid level is too high. The fluid comes out on either side of the bottom of the casting from holes in flat-bottomed "notches" in the otherwise curving casting.
If the "leak" you see is coming out of these holes, this is where your tractor is getting rid of the fluid from the overfilled transmission you noted. It will really pour out if you're working rough ground, or going downhill. Messy, but not a problem as far as your tractor is concerned.
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
