Re: difference between pistons
Posted by Janicholson on October 03, 2005 at 11:43:43 from (199.17.6.175):
In Reply to: Re: difference between pistons posted by Charles McNelly III on October 02, 2005 at 17:33:06:
If you can have them in your hand, the way to check the compression boost is to use a beaker (with cc's or ml marked on the side). Put water in the beaker to the 200cc or ml mark. Put the piston crown into the water in the beaker until the water reaches the round top of the piston (the edges of the piston that remain in the cylinder when the engine is put together). Look at the amount the water rises in the beaker, and subtract it from the original level. Which ever piston has more crown displacement will give the highest compression. If you subtract the crown displacement from the total combustion chamber volume (Set the head flat and pour in water till the chamber is full, then measure water used), you get the assembled combustion chamber volume in CC's (with water 1CC=1ml=1gram). The displacement of the cylinder divided by the assembled combustion chamber volume gives compression ratio. (Area= PI times radius squared times the height of stroke --done using mm--)(all done in cc because it is easier and the way it is done even by hotrodders)There are 25.4 mm to the inch. Stay below 8.5:1 if you want to use unleaded regular. If you are hunting the ultimate, or running pure alcohol or propane, higher numbers can be used. I hope this helps some, don't be intimidated by numbers. JimN
Home
| Forums
Today's Featured Article -
Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
