Re: Check Ampere Gauge
Posted by Nat on October 06, 2005 at 20:29:34 from (64.80.108.52):
In Reply to: Re: Check Ampere Gauge posted by Easy on October 06, 2005 at 18:21:38:
Quite simply, the needle should move to the right of center while the tractor is running, and to the left of center when the tractor is not running. There's no set amount of needle movement for each specific tractor, contrary to what some people would have you believe. The charging systems are essentially the same on all these Farmalls, and the amount the needle moves depends on many variables:
1. How much load is on the electrical system (lights, etc.).
2. How good the charging system is (generator and regulator, or alternator).
3. The condition of the battery, or how much you had to crank the tractor to get it running (a weak battery will cause the needle to move farther to the right while the tractor is running).
In a nutshell, if it moves to the right when the tractor is running, it's working fine.
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
