Re: IH books
Posted by Owen Aaland on April 07, 2009 at 21:39:07 from (65.165.246.54):
In Reply to: IH books posted by Bob S. on April 07, 2009 at 21:11:39:
There is an aluminum spacer that goes across the main bearing cap in the back of the block. The long bolts go through the ends of this block. They need to be longer because they have to pass through the spacer before they can thread into the block. The threaded hole in the center of the spacer should have a stud in it instead of using a bolt. It is very easy to over tighten the center bolt and strip the threads out of the aluminum.
When checking leaks in the front corners of the oil pan be sure to check for a crack in the pan.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
