Re: Crankshaft Pully
Posted by Wayne Swenson on October 23, 2005 at 17:36:07 from (66.191.70.114):
In Reply to: Crankshaft Pully posted by Gene37 on October 23, 2005 at 15:48:08:
It is just an interference fit; a tight one at that! Use a heavy duty bearing separator and 2-jaw heavy duty bearing puller. Since you are going to replace the seal, some heat from a torch will help loosen the cast pulley. It is brittle so be very careful; do not pull on the edges of the belt flange or breakage will occur. When re-installing, be sure all rough edges are removed and the pulley keyway is aligned with the key on the crankshaft. Make a plate or find a heavy pipe so you can pound on the center of the pulley (see above paragraph concerning belt flanges). Heat the pulley to 200 degrees or so and it will go on rather easily. Pound until the pulley is fully installed on the crank. Did you remember to put some assembly lube on the inner edges of the oil seal? Dry seals and dry shafts make heat & wear when first starting the engine until oil is finally splashed around.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
