Re: Fan Belt Adjustment On M
Posted by Sheepdog on October 24, 2005 at 18:39:42 from (67.0.14.175):
In Reply to: Fan Belt Adjustment On M posted by Paul in WI on October 24, 2005 at 18:19:45:
The rotating collar has a set screw in it and a locking nut (ahead of belt). Back out screw, use big water pump pliers or something to tighten collar. It helps to turn fan once in a while to let belt crawl up in pulley. The large diameter threads have four slots running front to back that the set screww will seat in when you are done. Lock nut. You might have to soak collar and threads with something, sometimes they are seized up.
Post a Followup
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
