Re: Fan Belt Adjustment On M
Posted by john d on October 24, 2005 at 21:28:12 from (69.128.204.133):
In Reply to: Fan Belt Adjustment On M posted by Paul in WI on October 24, 2005 at 18:19:45:
The adjustment is by means of a threaded sheave on one side of the pulley located on the fan hub. Look closely at that pulley, and you'll see threads on the front portion of the hub. You'll also find a set screw with a locking nut on it. Loosen the nut, then remove the set screw. Actually you don't have to totally remove it, but....it may have been 20-30 years since that pulley's been adjusted. My advice is to remove it totally. Spray some good penetrating oil into the hole where the set screw had been, and turn it up on top so the oil can start working on the threads. If you have a wire brush, clean the threads in front of the pulley. If you don't have a wire brush, use an old toothbrush and some carb cleaner or more penetrating oil. When the threads look pretty clean, use a long punch and a hammer to TAP on the raised boss opposite where you removed the set screw. Tap it one way for a while, then the other way, until it starts to turn. (Note: do NOT CLOBBER THAT HUB AND BREAK IT!) Patience is required in this adventure! Once the hub has been cleaned and loosened until it will turn freely on those threads by hand, you're ready to put on a new belt, tighten the hub, and re-install the set screw. Don't forget the lock nut! The end of the set screw is supposed to go into the groove machined into the threaded portion. I replaced the one my '49 M a couple of years ago, and it took me well over an hour to get it all cleaned, loose, and put back together. It's amazing how much dirt can lodge in those threads! The belt does not have to be extremely tight to work well. A similar system is used to tighten the generator belt, with the movable pulley sheave being on the generator.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
