Re: 504 gas
Posted by El Toro on October 27, 2005 at 04:12:21 from (152.163.101.13):
In Reply to: Re: 504 gas posted by ps on October 26, 2005 at 18:39:13:
You could probably just put a set of new rings in it if there's no grooves worn into the cylinder walls. You may have a broken ring and you will need a ridge reamer to cut away the ridge so you don't damage the pistons. The best way to check for wear is to measure the cylinders. You should have a shop manual that covers that 153 engine. The ring gap on a new ring will also determine if the cylinders are worn too much. My IH manual doesn't cover the 504, but it does list the ring gap for Farmall H with the C152 engine and the ring gap should be .007" to .017" on a new ring. You need close bearing clearances too and that includes cam bearings for good oil pressure. New gears in the oil pump if worn severely too. I do have a sketch of that oil pump listing the parts. If you're in doubt about the wear have someone measure the cylinders. You may need new piston pins and bushings since they can cause noise with new rings. Valve guides need to be checked for wear too. Hal
Home
| Forums
Today's Featured Article -
Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
