Re: H locked up in 2nd gear
Posted by Jay (ND) on November 01, 2005 at 12:38:33 from (66.231.118.95):
In Reply to: H locked up in 2nd gear posted by jim in columbus on November 01, 2005 at 11:21:49:
I'm not even close to the most qualified to answer this, but until someone else comes along, it appears that I am all you have. No, you don't have to take off the main deck. What you have to do is follow the gear shift down to the tube coming up from the deck. On the sides of that tube, there may or may not be welch plugs. If there is, remove them. If not, you will see approx. a 5/8" hole. In that hole is a pin. Push that pin out one side or the other. You may have to push down on the gearshifter a bit to relieve some pressure. Now the gearshifter should just lift straight out. In that hole, you will see the rails. 2nd gear is on the 2nd one from the left. If I remember correctly, you have to put the shift lever forward to get to 2nd gear - that would push the spoon of the shifter backwards. So your second rail is stuck rearward. Get a screwdriver and push it forward. You may have to rock the tires a bit while doing this. Now you can put it all back together in reverse order, however, I would take the spoon on the bottom of the shifter and build it up with weld and grind it down to the right size. That should keep it from happening again for a long time.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
